![I18n Error: Missing interpolation value "ImageAlt" for "Carica immagine in Galleria Viewer, {{ ImageAlt }}"](http://it.ecoflow.com/cdn/shop/files/power-station-portatile-ecoflow-delta-2-max-50999888707933_400x@2x.png?v=1701671149)
![I18n Error: Missing interpolation value "ImageAlt" for "Carica immagine in Galleria Viewer, {{ ImageAlt }}"](http://it.ecoflow.com/cdn/shop/files/ecoflow-delta-2-max-portable-power-station-50873176621405_400x@2x.png?v=1701671149)
![I18n Error: Missing interpolation value "ImageAlt" for "Carica immagine in Galleria Viewer, {{ ImageAlt }}"](http://it.ecoflow.com/cdn/shop/files/ecoflow-delta-2-max-portable-power-station-50873176457565_400x@2x.png?v=1701671149)
![I18n Error: Missing interpolation value "ImageAlt" for "Carica immagine in Galleria Viewer, {{ ImageAlt }}"](http://it.ecoflow.com/cdn/shop/files/ecoflow-delta-2-max-portable-power-station-50873176490333_400x@2x.png?v=1701671149)
![I18n Error: Missing interpolation value "ImageAlt" for "Carica immagine in Galleria Viewer, {{ ImageAlt }}"](http://it.ecoflow.com/cdn/shop/files/ecoflow-delta-2-max-portable-power-station-50873176555869_400x@2x.png?v=1701671149)
![I18n Error: Missing interpolation value "ImageAlt" for "Carica il modello 3D in Gallery Viewer, {{ ImageAlt }}"](http://it.ecoflow.com/cdn/shop/files/preview_images/D2Meu_400x@2x.jpg?v=1684740763)
![I18n Error: Missing interpolation value "ImageAlt" for "Carica immagine in Galleria Viewer, {{ ImageAlt }}"](http://it.ecoflow.com/cdn/shop/files/power-station-portatile-ecoflow-delta-2-max-51004541337949_400x@2x.webp?v=1701671149)
![I18n Error: Missing interpolation value "ImageAlt" for "Carica immagine in Galleria Viewer, {{ ImageAlt }}"](http://it.ecoflow.com/cdn/shop/files/ecoflow-delta-2-max-portable-power-station-50873176654173_400x@2x.png?v=1701671149)
![I18n Error: Missing interpolation value "ImageAlt" for "Carica immagine in Galleria Viewer, {{ ImageAlt }}"](http://it.ecoflow.com/cdn/shop/files/power-station-portatile-ecoflow-delta-2-max-54660724556125_400x@2x.png?v=1706619400)
![I18n Error: Missing interpolation value "ImageAlt" for "Carica immagine in Galleria Viewer, {{ ImageAlt }}"](http://it.ecoflow.com/cdn/shop/files/ecoflow-delta-2-max-portable-power-station-50873176588637_400x@2x.png?v=1701671149)
![I18n Error: Missing interpolation value "ImageAlt" for "Carica immagine in Galleria Viewer, {{ ImageAlt }}"](http://it.ecoflow.com/cdn/shop/files/power-station-portatile-ecoflow-delta-2-max-51032099094877_400x@2x.png?v=1706619220)
![I18n Error: Missing interpolation value "ImageAlt" for "Carica immagine in Galleria Viewer, {{ ImageAlt }}"](http://it.ecoflow.com/cdn/shop/files/power-station-portatile-ecoflow-delta-2-max-51942631309661_400x@2x.png?v=1706619220)
![I18n Error: Missing interpolation value "ImageAlt" for "Carica immagine in Galleria Viewer, {{ ImageAlt }}"](http://it.ecoflow.com/cdn/shop/files/power-station-portatile-ecoflow-delta-2-max-51942631342429_400x@2x.png?v=1706619220)
![I18n Error: Missing interpolation value "ImageAlt" for "Carica immagine in Galleria Viewer, {{ ImageAlt }}"](http://it.ecoflow.com/cdn/shop/files/power-station-portatile-ecoflow-delta-2-max-51942631244125_400x@2x.png?v=1706619220)
![I18n Error: Missing interpolation value "ImageAlt" for "Carica immagine in Galleria Viewer, {{ ImageAlt }}"](http://it.ecoflow.com/cdn/shop/files/power-station-portatile-ecoflow-delta-2-max-51942631276893_400x@2x.png?v=1706619220)
![I18n Error: Missing interpolation value "ImageAlt" for "Carica immagine in Galleria Viewer, {{ ImageAlt }}"](http://it.ecoflow.com/cdn/shop/files/power-station-portatile-ecoflow-delta-2-max-51942632882525_400x@2x.png?v=1706619220)
![I18n Error: Missing interpolation value "ImageAlt" for "Carica immagine in Galleria Viewer, {{ ImageAlt }}"](http://it.ecoflow.com/cdn/shop/files/power-station-portatile-ecoflow-delta-2-max-51942631539037_400x@2x.png?v=1706619220)
![I18n Error: Missing interpolation value "ImageAlt" for "Carica immagine in Galleria Viewer, {{ ImageAlt }}"](http://it.ecoflow.com/cdn/shop/files/power-station-portatile-ecoflow-delta-2-max-52799150293341_400x@2x.png?v=1706619220)
Alimenta ogni giorno nei prossimi 10 anni
EcoFlow DELTA 2 Max
![](http://it.ecoflow.com/cdn/shop/files/PC_-_2-KSPs-IT.png?v=1685009171&width=1000)
Batteria LFP di lunga durata fino a 10 anni
Durevole, sicuro, leggero
Grazie alla chimica della sua batteria LFP aggiornata, DELTA 2 Max ha una durata di 3.000 cicli completi prima della riduzione all’80% della capacità. Questo corrisponde a circa 10 anni di energia, anche se lo utilizzi tutti i giorni. Dura 6 volte più delle altre centrali elettriche con capacità e uscita simili.
![](http://it.ecoflow.com/cdn/shop/files/10-year-PC-IT.png?v=1685456386&width=1000)
Chimica LFP della batteria
![](http://it.ecoflow.com/cdn/shop/files/PC-LFP_Battery_Chemistry.png?v=1685449621&width=1000)
Protezione BMS avanzata
Un sistema di gestione della batteria integrato regola i parametri vitali, inclusi tensione, corrente e temperatura, così da mantenere DELTA 2 Max sicuro, protetto e in grado di superare la prova del tempo.
![](http://it.ecoflow.com/cdn/shop/files/PC-Advanced_BMS_Protection.png?v=1685449622&width=1000)
Strati protettivi all’interno e all’esterno
![<p>Grazie alle celle LFP, DELTA 2 Max è sicuro, durevole e altamente efficiente.</p>](http://it.ecoflow.com/cdn/shop/files/PC-With_LFP_cells.png?v=1685449620&width=1000)
![<p>La base antiscivolo in gomma e l'involucro ignifugo UL94-5VA offrono diversi livelli di protezione.</p>](http://it.ecoflow.com/cdn/shop/files/PC-A_rubber_anti-slip_base.png?v=1685449620&width=1000)
![](http://it.ecoflow.com/cdn/shop/files/PC-With_LFP_cells.png?v=1685449620&width=1000)
![](http://it.ecoflow.com/cdn/shop/files/PC-A_rubber_anti-slip_base.png?v=1685449620&width=1000)
![](http://it.ecoflow.com/cdn/shop/files/PC-Robust_Design.png?v=1685449620&width=1000)
Design robusto
Dal robusto design monoblocco, DELTA 2 Max è pensato per resistere ai percorsi accidentati della trasportabilità. Ogni porta è rinforzata, in modo da essere protetta contro l’usura.
![](http://it.ecoflow.com/cdn/shop/files/PC-Upgraded_Tech_Lighter_Weight.png?v=1685449620&width=1000)
Tecnologia aggiornata, peso ridotto
Persino con la sua batteria aggiornata, DELTA 2 Max rimane più leggero del 30% rispetto alle power station LFP da 2 kWh simili disponibili sul mercato.
Metti in funzione il 99% degli elettrodomestici con X-Boost.
Alimenta praticamente a qualsiasi cosa con un’uscita fino a 3.100 W
DELTA 2 Max alimenta quasi tutti i dispositivi di cui hai bisogno con un’uscita CA di 2.400 W. Inoltre, grazie alla tecnologia proprietaria X-Boost, puoi mettere in funzione apparecchiature con un’uscita fino a 3.100 W. Rispetto alle altre power station, DELTA 2 Max può alimentare più dispositivi, evitando al contempo il sovraccarico e il surriscaldamento.
![](http://it.ecoflow.com/cdn/shop/files/PC-Run_99_of_Appliances_with_X-Boost..png?v=1685449622&width=1000)
![](http://it.ecoflow.com/cdn/shop/files/PC-_9-icon-IT.png?v=1684824571&width=1000)
Estensibile fino a 6 kWh
Triplica la potenza
Porta DELTA 2 Max con te ovunque come unità singola oppure collegalo a due batterie supplementari per un massimo di 6 kWh di backup domestico.
![](http://it.ecoflow.com/cdn/shop/files/PC-Expandable_up_to_6kWh.png?v=1685449622&width=1000)
Ricarica fino all’80% in soli 43 min*
La ricarica CA e solare più veloce al mondo in soli 43 minuti
Grazie alla tecnologia aggiornata di DELTA 2 Max, combina energia solare fino a 1000 W con CA per velocità di ricarica leader a livello mondiale. In soli 43 min, hai già l’80% di ricarica. Oppure, utilizza l’AC raggiungendo l’80% in 53 min. *Utilizzando insieme CA ed ingresso solare, si dispone di 2400 W, di cui 1800 W di CA e un massimo di 600 W di ingresso solare.
![](http://it.ecoflow.com/cdn/shop/files/PC-Mask_group.png?v=1685449622&width=1000)
Sistema a doppio ingresso solare con tecnologia MPPT indipendente
Porta al massimo la generazione di energia solare collegando più fonti fotovoltaiche
Grazie al nostro innovativo design a doppio ingresso solare, ognuno con la propria tecnologia MPPT (Maximum Power Point Tracking) indipendente. Sfrutta un’integrazione regolare di potenza solare a casa tua o in ufficio, con pannelli solari multipli o con una combinazione di installazioni a tetto o a terra, catturando ogni raggio di sole.
![](http://it.ecoflow.com/cdn/shop/files/PC_-_14-99_MPPT_Efficiency.png?v=1684403043&width=1000)
Ingresso solare fino a 1000 W
Ingresso solare di 1000 W, ricarica completa in 2,3 ore, collegando fino a 2 pannelli solari portatili da 400 W o 4 set di pannelli solari bifacciali da 220 W EcoFlow.
Tempi di ricarica solare
1000 W Circa 2,3 ore
880 W Circa 2,6 ore
800 W Circa 2,8 ore
![](http://it.ecoflow.com/cdn/shop/files/PC_-_16-5-Year_Warranty.png?v=1684403031&width=1000)
Garanzia estesa di 5 anni
Con una delle garanzie più complete nel settore, facciamo tutto il possibile per assicurare la tua tranquillità.
Silenzioso come 30 dB
Ricarica senza problemi
Con soli 30 dB, DELTA 2 Max è più silenzioso rispetto alle altre power station da 2 kWh sul mercato.
*Da una distanza di circa 50 cm, il livello di rumore è pari a 30 dB (con basso ingresso e uscita di 500 W) rispetto ad altre power station da 55 dB o più."
![](http://it.ecoflow.com/cdn/shop/files/PC-As_Quiet_as_30_dB.png?v=1685449622&width=1000)
Serie DELTA 2
Soluzione di alimentazione a batteria LFP espandibile
La serie DELTA 2 offre una scelta da 1 kWh a 3 kWh per DELTA 2 e da 2 kWh a 6 kWh per DELTA 2 Max. Arriva all'80% della capacità iniziale dopo 10 anni di utilizzo quotidiano grazie alla chimica della batteria LiFePO4, che offre oltre 3000 cicli completi di carica e scarica e una durata 6 volte superiore alla media del settore.
![](http://it.ecoflow.com/cdn/shop/files/18-Delta_2_series_pc.png?v=1685450315&width=1000)
Contenuto della confezione
DELTA 2 Max
![DELTA 2 Max](http://it.ecoflow.com/cdn/shop/files/PC_-_19-1-DELTA_2_Max_535x.png?v=1684403031)
Cavo di ricarica CA
![Cavo di ricarica CA](http://it.ecoflow.com/cdn/shop/files/AC_charging_cable_535x.jpg?v=1699342606)
Cavo di ricarica auto
![Cavo di ricarica auto](http://it.ecoflow.com/cdn/shop/files/PC_-_19-3-Car_charging_cable_535x.png?v=1684403030)
Cavo da DC5521 a DC5525
![Cavo da DC5521 a DC5525](http://it.ecoflow.com/cdn/shop/files/PC_-_19-4-Car_charging_cable_535x.png?v=1684403030)
Manuale utente e scheda di garanzia
![Manuale utente e scheda di garanzia](http://it.ecoflow.com/cdn/shop/files/PC_-_19-5-User_manual_warranty_card_535x.png?v=1684403031)
Specifiche
Capacità
2048Wh
Batteria supplementare
Supporta fino a due batterie DELTA 2 Max Smart Extra / batteria DELTA Max Smart ExtraSupporta fino a due batterie DELTA 2 Max Smart Extra / batteria DELTA Max Smart Extra
Uscita CA
4 prese, 2.400W totali (picco 4.800W)
Potenza massima del dispositivo (con X-Boost)
X-Boost 3.100W
Uscita USB-A
2 porte, 5 V, 2,4 A, 12 W max per porta
Ricarica rapida USB-A
2 porte, 5V, 2,4A / 9V, 2A / 12V, 1,5A, 18W Max
Uscita USB-C
2 porte, 5/9/12/15/20V, 5A, 100W Max per porta
Corrente in uscita dell’auto
1 porta, 12,6V, 10A, 126W Max
Uscita DC5521
2 porte, 12,6 V, 3 A, 38 W max per porta
Ricarica CA
Carica rapida X-stream 2300W, 10A
Ricarica solare
11-60V 15A, porta singola 500W; porta doppia 1.000W
Tensione di ingresso CA
220- 240 V~ max. 10A 50/60 Hz
Ricarica auto
Supporto batteria 12V/24V, 8A
Chimica della batteria
LFP (batteria LiFePO4)
Ciclo di vita
LFP (LiFePO4 battery)3.000 cicli fino a oltre l’80% di capacità
Connettività
3000 cycles tBluetooth, Wi-Fio 80+% capacity
Dimensioni
49.7 × 24.2 × 30.5 cm
Peso netto (kg)
23 kg
